Originally Posted by
pcsguy88
I have a puller, but really need something that puts them back on. A hammer only works when the pinion is at the end.
If you don't have a sleeve like Gary uses in his method you could also cut down the shaft length with a dremel. If you go this method you can also turn the cutting wheel and grind a flat spot on the motor shaft if your going to a pinion that uses a grub screw.
