RCU Forums - View Single Post - Best Second Plane
Old 12-18-2016 | 10:34 PM
  #38
52larry52
skyflier, AND FURTHER MORE........no, just kidding. I don't mean to go on forever over this but I do want to add that the GP Cherokee and the Phoenix Cessna 182 both also look like good choices. All three, the Cub, the Cherokee, and the 182 are all in the same general price area so cost is not a factor, just buy the one that YOU like the most. The Cub is the largest and will have an 81" one piece wing, Can you transport an 81" wing? The Cub will be the biggest floater of the three and may need the longest runway, how much runway does your club have? On the plus side, @81" the Cub can fly in "giant scale" events. The Cherokee has a lot of dihedral and should be a stable low winger and is the same size as your trainer. The 182 is only slightly larger than your trainer. Both the Cherokee and the 182 are tricycle gear not needing taildragger skills. All three will fly well on an O.S. 46 AX. So it comes down to....which one do you like most?
