Originally Posted by
olnico
Here is my setup.
This is a 20 by 10 feet prefab aluminum/ steel frame shed that is modified for painting.
1. Silicon joints laid up on the outside of the room between each panel.
2. Double rubber seals on the doors.
3. 28" extraction fan with evacuation through the roof of the factory ( was prefab structure is built inside the factory )
4. Incoming air filtration through 3 large roof panels with synthetic felter
5. Extraction air filtration with a specific media ( not sure what it is )
6. Specific painting room neon bulbs ( very cold neon light that magnifies the paint imperfections )
I had a bit of a hard time to seal the room from dust initially. Took several trials and passes with silicon before the setup was good enough for proper painting.
Hmm....
I didn't know you were an SR-71 aficionado Oli, is that yours? Judging by how much of the room it fills up and the dimensions you gave for the room, that's 'gotta be a pretty good sized project. I always really liked that airplane going back to when it was originally known as a YF-12A.
Hard to tell from a picture on the Internet, but it sure looks good!
