Originally Posted by
culver
Go to hardware store and buy a quart of denatured alcohol, rubbing alcohol has a high percent of water which probably effects the ability to mix.
If you're going to spend $10 on that, may as well get the finishing resin found one isle over? These chemistry experiments with unmeasured cocktails, doesn't sound like stuff I want screwing up my plane after all that build time. Make sure if you want to play chemist games, log the amounts you're using(wasting) and practice on a scrap piece first to see if it ever cures properly (more waste).
