RCU Forums - View Single Post - Fuel in different turbines??
Old 12-30-2016 | 06:41 PM
afterburner's Avatar
afterburner
My Feedback: (18)
Originally Posted by gsmarino2000
Kingtech has a couple of specific turbine oils they exclude due to observed coking problems, and I think all 2-stroke motorcycle oils. But to the best of my knowledge they do not require you to use Kingtech oils. I do use theirs since I only have Kingtech's, but others at my field use generally available turbine oils. For more information on what Kingtech will and won't warranty, contact Dirk or Barry. There are also threads on this topic on the Kingtech support forum.
Greg
From the Kingtech engine manual:
KingTech engines use Diesel, 1-K kerosene or Jet-A1 for fuel. Fuel must be mixed with 5%KingTech Special Blend or synthetic turbine oil (Aeroshell 500 and all 2-stroke oil areprohibited), or 1 quart of oil in every 5 gallons of fuel. Among the above 3 types of fuelKingTech highly recommends using regular pump Diesel as they are readily available,inexpensive and having a higher energy density and up to 10 to 12% better fuel efficiency. For best result and full core warranty, use KingTech Oil only, it is proven to be the cleanestand has the best lubrication properties for our engines, please refer to the below comparisonchart:
