RCU Forums - View Single Post - Probably User Error - but need Help
Old 12-31-2016 | 08:01 PM
tree2tree
Default Probably User Error - but need Help
Hi,
I was setting up a new glider model on my SZ18 and reassigned motor to slider LS (Assigned Camber to RS). I also enabled the MOTOR function, and assigned SD to activate it. After I turned the transmitter off and on again, it powers up in RF OFF mode, displays MOTOR, and sounds the warning beep like the throttle is not at idle. I have moved LS to both limits, and SD to all 3 positions, but I cannot get it out of that RF OFF mode. The only way to get out of RF OFF mode is to INH the Motor function. Am I doing something wrong?
Or is there another way to achieve what I want to do:
SD is UP = CONDITION 1 = motor-on launch with ESC controlled by LS.
SD is MIDDLE = CONDITION 2 = camber controlled by RS, and no motor possible
SD is DOWN = CONDITION 3 = butterfly controlled by J3, and no motor possible
Hope you can help,
