Originally Posted by
mr_matt
I agree with this set up. Run 2 each receivers over SBus to the gyro, then PWM out of the gyro to the servos.
And you wont need an extra SBus decoder as you will have many PWM outputs available from the 2 receivers for non stabilized channels (flaps, gear, throttle, etc)
But doesn't the power box allow me to run 15 channels directly from it? Why would I use any of the outputs from the rx's to run the non stabilized channels?
Patrick
