Hey if you have 2,5 gal of fuel through the engine you can lean the idle and the top end. I suggest adjusting the top end with the full throttle setting at 3/4 open on the carb and idle such that the engine stays running for quite a while. If too lean the engine will run quite awhile and then quit. I hope to see photo's of your Stearman. -Tom
