RCU Forums - View Single Post - Best Second Plane
Old 01-07-2017 | 01:14 PM
  #97
J330
Originally Posted by hsukaria
Received the VStik a few days ago in good condition. It is a quick assembly since since very little work left to finish. The only big job is modifying it to taildragger if the user decides to. The engine mount fits my OS 46SF perfectly. Maybe the OS 46 FX/AX are bigger? So, no work required for engine mounting. Covering is a whole other story....
I'm glad yours made it. I heard from VMAR support they've corrected the engine mount issues. SF is exactly the same width of FX/AX. The HP I used is LA .40 width, same as FX .25 I believe.
Yeah the covering, you cut it, it doesn't stick to anything, it's only sticking to itself. Monokote isn't much for a boxy fuselage though.
I sold my RTF V Stick in the photos for $100 locally. I've never been happier. What do you think of the hatch covers? Servo horn connectors?
What exactly makes turning it into a tail dragger a big task? I didn't see any obstacles preventing that from being easy;
Epoxy in some plywood, drill some holes, move the gear forward, and add a rear skid.
Name:	Screen Shot 2017-01-07 at 4.17.59 PM.png
