Bill I just checked mine and didn't notice any. I did have one of the plastic inserts work loose on the 5th flight. Re-glued it and it is fine also check the other one. It is good. I know of one other one that found the Ball heads on the servo arm backing off and loose. I check mine every time in preflight.
It's a keeper in the air. best of luck with yours.
Jeff
