RCU Forums - View Single Post - Plan Modifications
Old 01-10-2017 | 08:23 AM
Bax
You can use rubber cement to bond the layers together, 3M #77 spray adhesive (very lightly), or similar. Use Ronson lighter fluid to remove the adhesive. When cleaned-up, there's not enough residue left on the wood to worry about. You can also use re-stickable glue sticks to hold the layers together.
Lots of alternatives.
