RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 10-26-2003 | 11:53 AM
  #1533
jrjohn
My Feedback: (24)
Default RE: U Can Do 3D
matt, who told you that you had to cut or tap your engine? First of all save yourself some money and buy the Iron Bay Regulator. It also comes with the oneway valve and T you will need to preasurize your fuel tank. Here is the set up.
You only need two lines to the tank
1.The fuel line that runs from your exhaust will have the supplied oneway valve in it. It will allow preasure to build in the tank, but not come back out.
2 Between the oneway valve and the fuel tank(SAME LINE) you will put the T conector and run one line wild out the bottom of the cowl. You will have to put a plug in it. (GOLF TEE ECT) This is so you can remove the plug when fueling, or taking fuel out of the tank. Remember you now have a closed preasurized system so if you don't provide a vent for fueling you will expand and rupture the tank. (the reverse when taking fuel out)
3. Now the other fuel line.... Come out of your tank, into the regulator, out of the regulator and connect to the carb.
No cutting, nipping, slicing, diceing, taping ect. maybe the Cline needs all this I don't know.
Everything comes with the Iron Bay Regulator for $43.00 plus shipping.
John
