Hi LXbuilder Just a thought on carrying the Senior in a coupe or small car. The wing either the 78" kit version or the 80" Arf version is not normally the problem when over the passenger seat or along the side.
As one of the fellows mentioned above the fuselage is the real problem in a small vehicle. So here is the solution one of my past sudents come up with for his Senior about five ears ago:
Sorry for the mistake and the double post of on photo.
Also Kudos to you LXBuilder for considering the two stroke glow engine. Often these days two stroke is touted as a bad choice when in fact many can be wonderful choices. I have done Seniors with no engines, engines up to 1.0 cubic inch and as small as .35 cubic inch, up to four engines and even up to a 13 lb thrust jet turbine.
Back to that .35 though (that is a modern OS .35 AX) Yes it is even smaller than Sigs official recommendation But I still keep that ship as my main go trainer for mentoring the fellows it is simply a superb combination.
John
