Originally Posted by
GallopingGhostler
Interesting, Mr Cox, you do have an oddity. I can see why Leroy Cox discontinued the earlier 1950's rear rotary valve versions. They were more expensive to make and thus less profitable and less marketable over their other engines.
The mid to late 50s Cox engines you refer to were DRUM valve-not rear disc-known as the RR-1. Cox's terminology was incorrect. The drum was much smaller in diameter (the major rotating mass)-and machined from steel-so the drive flange which engaged the crankpin could be a lot thinner than a disc valve setup-about 1/32" or so-and the drive was via a hole-but a radial slot from the outer edge also works (and is less stringent on alignment. Being hardened steel and ground the material was a lot less prone to galling and wear than the Valentine disc setup-and the RR-1 engine used a shaft with an extended crankpin having a reduced diameter extension. (see second pic) [this was reasonably common practice on some European engines as well-in some cases the drive pin simply pushed into a hollow crankpin-allowing the same shaft to be used for either FR or RD layouts]
Also-being ground-the fits could be a lot closer and more precise than the aluminium disc used in the current breed of Valentine rear rotary valves. Naturally they (the RR-1) were more expensive than the reed valve coxes to produce-and presumably that was why Cox dropped them. A pity really-as I would take an RR-1 over a Babe Bee any day. Some stuff was just silly-the machined ribbed tank and thev ribbed crankcase nose for example-which was purely for appearance-but must have added significantly to the production cost. Likewise the anodised case which though it presents a nice contrast could have been left plain [though I admit the RR-1 is one of the most visually attractive Coxes made-the other IMHO is the Olympic 15] Cox could have achieved the same visual effect simply by anodising a plain machined Bee tank bell blue...and anodising a standard reed valve case yellow for effectively the same visual effect.
ChrisM
'ffkiwi'
