RCU Forums - View Single Post - Strange problem with Clark TK60G2
Old 01-20-2017 | 10:57 AM
Crius
Originally Posted by kultakala
Okay, now its working... i really tried everything but Clark had finally the right idea!
There is a function to switch gears for some tanks, when powering on the board is set to neutral gear.
And while in neutral the throttle is not working.
In the special case with a differential gearbox the throttle switches to a different channel so the throttle works but not the steering.
So it was just a configuration issue, which is very well hidden in the guide.
Problem solved
So let's see some video of that Bad boy!
