Originally Posted by
sollie
good to see you solved it . Was chatting with Clark now tonight about your issue. Just wanted to make sure about a few things before I jumped in here .
He also updated a few spots in the info on his page .
Its my first tank and the last r/c model i built, that was back in the 80ies !
Some info is not easy to put together, like the neutral gear thing. And some are missing, i did not find a diagram about the Board connector for the Programmer, its only visiblöe on one of the photos, so i made it like there and it worked.
But could be that overlooked it.
One question i had was about the tail lights... they only light up when GBS is enabled ?
I thought they would be parallel to the front lights, but for that i have to connect them to the same connector as the front lights, is that correct ?
And then without a resistor in line ?
My tank is technically almost done... but i did nothing yet with the outer hull or turret. No decals, no paint, nothing...
But i will show some video next week.
