This might sound silly, try running 4 stroke glow fuel thru it with the ignition. Before I sold mine, that was the only way I could run it. The problem with that Saito motor is it's a glow needle valve trying to run gas, doesn't work. Works fine with glow fuel and you never have a dead stick. Problem is you are still using expensive glow fuel so no savings....
