Hmm, some of this fits the Do18. But that 5000 mile flight doesn't jive.
Sir; you are correct. The Do 18 did not fly 5,000 miles. It flew 5,214 miles. Nevertheless, you nailed it and congratulations are in order. Well done! And, you are now up. We await your question.
Two points bear highlighting. The first is that the record setting flight of 5,214 miles (see clue 6) began at Start Point, Devon, England. A little play on words there. And the Do 18 was not only the first German aircraft to be shot down by British aircraft in WWII; it was also (same aircraft, actually) the first German aircraft to be sunk by a British warship. Interesting. Very interesting. Thanks; Ernie P.
What warbird do I describe?
Clues:
1. This aircraft was the most important of its type, at the time, for its military.
2. But it was also the only one of its type, at the time, in its military.
3. It was developed for the military, but much of the testing was conducted by a civil aviation business.
4. This aircraft first flew in 1935.
5. This aircraft set a number of distance/speed records.
6. One of these aircraft set a distance record, flying over 5,000 miles from start point.
7. This was a development of an earlier type.
8. Two engines.
9. Monoplane.
10. Both aerodynamically and hydrodynamically superior to its predecessor.
11. The first prototype was lost during high speed tests.
12. When talking about “high speed”, that term must be qualified when discussing this aircraft. It was not a truly “high speed” aircraft.
13. In actual combat, it proved to be slow and vulnerable. And, lightly armed.
14. Crew of four.
15. Interestingly, one of these aircraft was the first to be shot down, in its war, by a British aircraft.
16. And also, the first to be sunk by a British warship.
17. The distance record breaking aircraft tended to be launched by catapult.
18. Probably because they couldn’t get airborne without one.
Answer: The Dornier Do 18
The
Dornier Do 18 was a development of the
Do 16 flying boat. It was developed for the
Luftwaffe, but
Lufthansa received five aircraft and used these for tests between the Azores and the North American continent in 1936 and on their mail route over the South Atlantic from 1937 to 1939.
On 27–29 March 1938, a "Do 18 W" established a seaplane record flying non-stop a straight distance of 8,391 km (5,214 mi) from
Start Point, Devon to
Caravelas in Brazil.
[h=2]Design and development[/h]In 1934, the
Dornier Flugzeugwerke started development of a new twin-engined flying boat to replace the
Dornier Do J "Wal" (Whale) in both military and civil roles. The resultant design,
Do 18 retained the layout of the Wal, with a metal hull fitted with distinctive stabilising
sponsons, and powered by two engines above the wing in a push-pull layout, but was aerodynamically and hydrodynamically more efficient. It was planned to be powered by two of the new
Junkers Jumo 205 diesel engines. Although heavy, these promised to give much lower fuel consumption than conventional petrol engines of similar power.
The first
prototype, the
Do 18a,
registration D-AHIS (and named
Monsun by Lufthansa) flew on 15 March 1935, powered by two of the earlier 410 kW (550 hp)
Junkers Jumo 5c diesels as the planned Jumo 205s were not yet available. It was lost on 2 November 1935 over the Baltic during high-speed tests. Three further prototypes followed, two (the Do 18d and Do 18b) being prototype military aircraft, and the Do 18c (later redesignated Do 18 V3), a civil prototype.
The Do 18c was delivered to Lufthansa as a Do 18E civil transport (
D-ABYM Aeolus), quickly followed by a further two aircraft, (
D-AANE Zyklon and
D-ARUN Zephir)[SUP]
[5][/SUP] with a final Do 18E (
D-AROZ Pampero) being built in 1938.
A further civil Do 18 was the
Do 18F, a modified aircraft with longer wingspan and higher weights built for extended-range flights. The sole Do 18F,
D-ANHR, first flew on 11 June 1937. It was later modified with 656 kW (880 hp)
BMW 132N
radial engines to test a possible upgrade for the Luftwaffe's aircraft, flying in this form on 21 November 1939 as the
Do 18L. It suffered cooling problems, however, and further development of the radial powered Do 18 was abandoned.
[h=2]Operational history[/h][h=3]Civil service[/h]In 1936, Lufthansa started a series of endurance trials, culminating on 10–11 September when
Zephir, flown by
Flugkapitän Blankenburg with Lufthansa Director Freiherr von Gablenz as passenger, was launched by
catapult from the seaplane tender
Schwabenland at
Horta, Azores, flying the 4,460 km (2,270 mi) to
New York City in 22 hours 12 minutes. Also on 11 September,
Aeolus flew from Horta to
Hamilton, Bermuda in 18 hours 15 minutes, continuing to New York the next day. For the main leg of the North Atlantic the aircraft needed the help of the catapult on
Schwabenland. On 22 September
Aeolus returned to Horta in 17:50 h (3850 km).
Zephir was catapulted on 28 September at Hamilton. The second Flights to New York followed on 5-6 and 6–7 October and the return flights this time, 17 and 18 October from
Sydney, Nova Scotia. The flying boats did not wait for their tender and went on to
Lisbon and
Travemünde.
The record-setting Do 18 D-ANHR in 1938.
In April 1937, D-ARUN
Zephir and D-ABYM
Aeolus started their service on the South Atlantic mail route from Bathurst, now
Banjul,
Gambia to
Natal, Brazil (3040 km). Catapult ships were based in Bathurst and
Fernando de Noronha to allow the aircraft to cross the Atlantic carrying a full load of mail.
In June they were joined by V6 D-AROZ
Pampero.
Aeolus was lost on 30 July 1937, when it had to make an ocean landing due to engine problems and was heavily damaged when
Ostmark tried to retrieve the plane.
Pampero (20 August) and
Zephir (29 January 1938) also had to make ocean landings.
Pampero was lost at sea nearly without trace on 1 October 1938 with a crew of five.
Lufthansa's fifth aircraft was the only
Do 18F V7 D-ANNE
Zyklon, that first took to the skies on 11 June 1937. This was the only Do 18 with a wider span which enable it to stay in the air with one engine out. This was a special demand of
Lufthansa Zyklon was used over the South Atlantic between September 1937 and March 1939. The Do 18s crossed the South Atlantic 73 times.
Zyklon is not the aircraft that established the England to Brazil distance record from 27–29 March 1938 as often stated.
The record-aircraft D-ANHR was taken from the military production line and was specially prepared. It was flown as a builder's machine with a Lufthansa crew augmented by the works pilot
Gundermann. On the way back to the South American station the seaplane tender
Westfalen took the aircraft in the English Channel where it was catapulted to Brazil. On the record flight the conditions were not optimal and the Do 18 did not reach Rio de Janeiro as planned.
[h=3]Military use[/h]In
Luftwaffe service, it was obsolete by the outbreak of World War II, but – as the only military flying boat – 62 (58 serviceable) in five squadrons were in use mainly on
North Sea reconnaissance missions. In 1940 some squadrons changed their base to Norway. The vulnerable and underpowered flying boat was soon relegated to training and the air/sea rescue role. In the middle of 1941, only one squadron was still operational on Do 18. The
Blohm & Voss BV 138 had superseded the Dornier.
A Do 18 was the first German aircraft to be shot down by British aircraft during the war, when one of a formation of three was caught over the North Sea by nine
Fleet Air Arm Blackburn Skua fighter-bombers of
803 Naval Air Squadron flying from
HMS Ark Royal on 26 September 1939. The flying boat was able to make an emergency landing but was sunk by the destroyer
HMS Somali.
Specifications (Do 18D-1)
Data from The Do 18...Dornier's Whale Calf
General characteristics
- Crew: 4
- Length: 19.23 m (63 ft 1 in)
- Wingspan: 23.70 m (77 ft 9 in)
- Height: 5.32 m (17 ft 5¾ in)
- Wing area: 98.0 m² (1,055 ft²)
- Empty weight: 6,680 kg (14727 lb)
- Max. takeoff weight: 8,500 kg (18,739 lb) (Normal take-off) (Catapult weight: 10,000 kg (22,046 lb))
- Powerplant: 2 × Junkers 205C-4 six-cylinder, vertically opposed diesel engine, 451 kW (C-engine) (605 hp) (take-off power) each
Performance
- Maximum speed: 250 km/h (135 knots, 155 mph) at sea level
- Cruise speed: 190 km/h (103 knots, 118 mph) (max endurance cruise)
- Range: 3,500 km (1,890 nmi, 2,175 mi)
- Service ceiling: 4,350 m (14,270 ft)
- Climb to 1,000 m (3,300 ft): 7.5 min
Armament
- Guns: 1 × 7.92 mm MG 15 machine gun in each of bow and dorsal positions
- Bombs: 2× 50 kg (110 lb) bombs under starboard wing
Start Point is a promontory in the
South Hams district in
Devon,
England,
grid reference SX832370. Close to the most southerly point in the county, it marks the southern limit of
Start Bay, which extends northwards to the estuary of the
River Dart.
The rocks of the point are
greenschist and
mica-
schist, formed by
metamorphism of
Devonian sediments during a period of mountain building towards the end of the
Carboniferous period.
The name "Start" derives from an
Anglo-Saxon word
steort, meaning a tail. This root also appears in the names of birds with distinctive tails, like the
redstart.
