Yes,
I have used the older 12v version and the XP since I switched to electric about 6 yrs ago.
What do you want to know about it?
You can charge a 1-10 cells pack or 2 packs up to 5 cells each. Charge rate is dependent on Voltage and current capacity of your Power Source, but is rated for 50+ amps
It provides individual cell voltage, and IR, and can discharge if you have a load to discharge to.
You can control and program charge rate by C, You can hook up a parallel board.
