RE: U Can Do 3D
coolmarlin is correct, the tank if too high. it will flood w/o a regulator. been there, done that!
You have to understand something.... when you read a thread as old as this one. all of the problems have been worked out. You get the correct CG. the right engine, the right thrust angle, servo's, linkages, fuel system and set up. what more could a person want.
