RE: hot bodies 3.5 engine specs
thanks, so if my well used up OSrz is rated at 2.5 and this is at 2.3 then it should be more or less as fast in the same car, which it is not. BTW when I say fast I don't mean top speed I mean 0 to 30 MPH.
My last tank only went to 200 degrees so It's time to lean it out another 1/8:-)
I just thought of something. The clutch! Hummm, the HB clutch may not be grabing like the identical one in hte OS.I'll have to check clutch spring and see if they are the same/
