The valve on the injector removes air from the line.
You should replace the ring with a new one if you hear the compression going down the crankcase, this engines when the ring is worn it will loose about half the power when they get to temperature in flight.
This engine will better work with Cool Power 30% high performance heli fuel, or it will most likely flame out eventually.
Regards
