Hi David,
Thank you for the suggestion, although it is still possible to detach the dolly while under power. I'm trying to figure out a mix to disable the release servo while the throttle is open. Sounds simple, but maybe I'm missing something! If I can't get an answer here I'll do as you suggest and try one of the other forums.
Alan
