Originally Posted by
TPerk
I am just wondering how much weight was needed to balance the turbinator including your batteries? I will have 3lbs 1.5 oz of weight in the nose including the batteries in that weight of 3lbs 1,5 oz, that seem like a lot of weight, I guess it is what it is. I am balancing it at 7" back from l e.
You might be a little on the high side with weight, but not way out. Mine has 28oz of lead along with two 2600 A123s, and a 2S, 4,000 LiPo pack and is balanced in the middle of the CG range. I'm running a relatively light engine (JC Rabbit) and took steps to put everything as far forward as possible.
