Thank for the replay, I have a King Tech 120, the engines weight is all most 3Lbs I used lead shot and epoxy for most of the weight and I will use a stick on weight to finest the balance, so if in need to take out some weight after my first flight I can remove some weight.
I added some great stuff foam to seal the epoxy and lead shot mix I had added to the nose.
