Originally Posted by
crankpin
Thanks for all photos. I have always on every build, surrounded the tank with foam rubber. Usually top and bottom. This build, no foam rubber anywhere. Have to slide the tank in like your photo Nauset. Foam rubber, always thinking vibration will cause the fuel to foam. I am going like you, sliding the tank without foam rubber.
Has vibration concerned any of you ? I am using the Saito 90TS twin, single carb.
Vince
I have always used foam around the tanks in my planes but I do have a few that because of the design there is no room for foam. I have not had any issue with the ones without foam. I even see now people mounting receivers without foam which used to be a no-no.
