Thanks for the help.
Edit: Wanted to edit to let you know why I was having such a hard time figuring this out. If you look at the default model that comes with the software for a taildragger it shows the distance from the mains to where you want the weight added is 1200 mm which is 47inches. So since the distance from mains to tail was 1000mm and the distance from mains to nose was 1200 I assumed this distance for the third measurement was the total length of aircraft. I was kind of looking at the default as kind of a guide to use.
Patrick
