Originally Posted by
TPerk
I am getting close to finishing my Turbinator and I need to set some down elevator mix with the flaps, may I ask how much down elevator are you guys using for half and full flap. I just need a good starting point and I will adjust the mix after I get a couple of flights on her. I balanced the plane 7" back on CG and I balanced it up side down, that seems to be better then right side up, I seem to be able to get a better balance point with the plane up side down.
My elevator to flap mix is easy, none. The only mix in my plane is rudder to steering. If it balloons when you drop the flaps you're going too fast. Remember, this plane was originally designed by one of the best model aircraft designers of all time and has no bad habits that I've found. Don't over think it, Turbinators are pretty much turbine powered ugly sticks. Use good servos, good linkages and balance it where the manual says and you'll have a nice, solid plane that is a great everyday flier. Not trying to sound like a fanboy, I just really like this plane. For the last few months it's the only thing I pull out of the trailer.
