Great video, I have also had great success using aero poxy on hatch joints, fuse joints where there is not much room for filler. The epoxy is much less likely to chip out on parts that are removed often. Use the same release system as the other filler. Yes it's harder to sand but you have lots of time to clean up the joint before it hardens.
