Originally Posted by
Shaun Evans
Sean,
GREAT video! I tried that 'Icing' stuff before, but I found it gummy. I think I see why.... compared to you, I used WAY too much catalyst. With the proper amount of catalyst, how do you find it sands?
If you're using a bar sander, how do you keep the end of it from digging into your wing skin? Are you doing all of this post-glassing? Thanks for doing the video, and thanks in advance for your answers.
Shaun, I do glass the wings/fins first before sanding against them. this gives a nice rigid base. I've not found the edge of the sanding block wanting to dig into the skin, but most of the sanding attention is given to the area where filler is applied first.
