Flaps will also give you a washout effect because they are inboard from the ailerons, so when you deploy them you have effectively a higher angle of attack near the fuselage, which is good. Drag issue mentioned by BobH is good to remember, might need to hold a little more throttle coming in so you don't slow down too much.
