RCU Forums - View Single Post - canard pusher config
Old 02-09-2017 | 02:18 PM
allanflowers's Avatar
allanflowers
My limited experience with canards resulted in a need for "upthrust" on the pusher engine. By that I mean that high engine power will then tend to put the plan in a climbing attitude (by pushing the tail of the aircraft down). This was after initial trials where the plane would NOT lift off, until I killed the throttle - at which time it would leap off the ground. The change in the thrust angle solved the problem. Now this might have been a result of a draggy undercarriage, lowering the aerodynamic center of the plane. I don't know. The plane survived, although had to be rebuilt a couple of times.
ID:	2200380   Click image for larger version
ID:	2200381   Click image for larger version
