Originally Posted by
540chevelle
Hey Chris. Nice work. I am at this spot in my build. Would love to do the same with the flaps and ailerons. Can you show a few pics of the inside and the linkage you used? I would love to keep it as concealed as possible. This looks awesome.
Thanks Jon
Thanks Jon,
i placed the the servo as far forward as I could which ends up next to the spar. The rib and the spar help box in the servos. Then the linkage is attached to the servo horn and it ends up coming out as you see, pretty low and further back at the TE. On the surfaces the horns are epoxied keeping in mind the center of the hinge pivot. I used a t-pin thru the lowest hole to set the height while it cured.
I'll take a couple of pics of the servo pockets for you.
