RCU Forums - View Single Post - E jato breaks
Thread: E jato breaks
Old 02-13-2017 | 04:09 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by Spnfull
I was told I had to drill holes and put pins in the tranny plate. Becuse with stock tranny the jato just rolls forward without residence. Do u know of a kit?
This is correct - because there is a one-way clutch bearing in the transmission. Spinning the engine (or now "motor") backwards and the car doesn't move. You will need to lock the Trans into second gear to use the motor as the brake. Otherwise just keep a servo mounted for what would have been throttle/brake and just change the linkage a bit so it is brakes only. I would think you should be able to use a Y-harness to allow the ESC and servo to occupy the throttle channel on the receiver.
