Originally Posted by
Propworn
If I could only have one saw I think the scroll saw would be the most versatile. Its the easiest one to do inside cuts just disconnect the blade pass the work over the blade and reconnect then you can cut out inside shapes. The band saw will only do this if you have the capability to break then re-weld the blade once it has been placed inside.
Dennis
Why not just pass the work over/under the blade?
