Further to my post as far as adhesives go. You can use epoxy but my favorite is guerrila glue. My technique for glueing is to not put glue on the hinge point but in the hole and then install the hinge point. Of course this is after dry fitting the hinge, counter sinking for the "hinge" and verifying the alignment between the fixed and rotational surface. I have yet to see any video talk about alignment or what happens when the hinges are not aligned properly.
