Originally Posted by
Malcolm H
What Dave says but before you install the spinner backplate, tack three 1/32" spacers 120 deg apart to the back of the backplate, so that when you hold it against the front of the fuselage there will be a small gap. If you don't do this when you finally install the motor, the backplate will touch the front of the fuselage.
Malcolm
Thanks Mal......yep...a small but crucial detail!!
