RCU Forums - View Single Post - Bolts Keep Coming Loose in the Header
Old 02-15-2017 | 10:22 AM
skyflier
Originally Posted by grotto2
Most of the problem is the mass of pipe, which results in it's inertia stressing the header/exhaust junction.
Soft mount the pipe at the pipe's CG.
Make an intermediate joint by cutting the header as short as reasonable and adding an additional silicon coupler at that point. You should be able to get a 3 to 6 inch piece of intermediate pipe.
The pipe will still wiggle around a lot, but the additional coupling will reduce the inertia transmitted to the header/exhaust joint.
I definitely agree with grotto2, It may be a little work, But it will be worth it in the long run.
