Outer flap servo
Hey All,
Was discussing with Gary offline a little bit ago and he thought be a good idea to post here to see if any others have found this. When doing the outer flap servo, I found the servo mounting doesnt match the pictures in manual or text at all. Mine is deeply recessed which as you will see in one pic causes the arm to hit against wood rib. The only thing we thought of doing is putting in some spacer behind servo mounting tabs to get it out further. Anyone else seen this? I received this kit straight from factory about 1.5 months ago.
As Gary pointed out, CARF is known for their uniformity which makes this a bit puzzling.
Z
