Dan, I am not going to scan them in. The problem with the plans is they aren't accurate as far as the shapes and sizes the years of them setting copies of the lines are distorted and warped to a small degree.. . I will redraw the entire short kit. there's enough info on the plans to get it right. I will test fit all parts on CAD before I have them cut. I do plan to "update" this model for flaps and retracts. I have also found several areas that without risking structural integrity I can lighten it up (Old plans).I am using AutoCAD 2014
