Originally Posted by
MAVROS
Hello all,
I now have 20 flights on the 185 red cdi and WOW this engine is absolutely amazing .
Much better than 175 cdi. Much less vibration and unlimited climb performance in the Galactik.......
I have reduced the oil content down to 12.5% cool power MV . And the break in / hot weather valve is fully closed
No oil residue on airframe after flight......
I am geting 7100 RPM. prop 20.5x10 APC.......still waiting for the bigger prop .
Sorry Papaone but I am not game enough to go any lower on the oil......
Ps: Have you blokes seen the new gadget from YS for fitting the Crankshaft back on....makes bearing change a half hour job
rgds
With the bigger prop, you should see around 68 - 6900.
I considered the crankshaft fitting tool, but decided it's not worth it.
I use a 2 thou feeler guage and 2 small screw drivers.
20 seconds and it's in.
