I had to elongate the holes in the aluminum brackets so the holes in the servos would line up. Having done that, I now had to secure the servos to the brackets with nuts under the bolts. Out of 8 holes (between the two servos) I actually had one line up so that did not need a nut. I used Loctite on all the bolts.
