Buck,
THANKS A MILLION!
Sean,
Nice! Any ballpark on pricetag?
I got some more work done. Got the steering hooked up and test-fitted the Brian Sauers detail stuff on the mains. I started doing the filling on the fin-tip joint with this Icing stuff. This stuff sands GREAT! I also cut out the flap pocket on one wing, got it lined with thin ply and glued in the servo mount. After that, I've gotta grind a hole in the ply lining I just glued, then bore a tunnel for the servo lead to intercept the existing tunnel for the aileron servo. The flap linkage will be almost totally concealed by the scale flap hinge.
