I too have a Triton 2. That 2000mah is a whopper of a battery. I use 700mah batteries in my Futaba transmitters and was not aware that the Triton had that limitation. Can't you cycle the pack outside the transmitter with the normal JR connector? You should also look into a charger with more capacity if you a going to continue to use that size battery. Dan.
