That is probably the best sound system I have heard. No delays, smooth transition as the tank moves off of idle, No give away that it is changing sound bytes. This sounds like a tank, and not a model playing recorded sounds. Good on Clarke for not giving up and advancing his system. I dislike his standard stick set up, but with some cable swapping you can get things more intuitive. Does the TK60 allow you to build your own files, and if it does, how is the software to use?
Cheers
Dan
