You are welcome Mirce, this will be a good resource for builders I hope.
The wings are so easy, I am just dry fitting the wing to check the parts, they look great. I installed the blind nut for the
tip tank installation, must do that before sheeting.
Had to make two small parts for the wing spars, one ply piece to cap the rib and another to add extra support
to the spar end. Plenty of scrap from the jig legs on the fuselage!
The tip tank looks awesome on the wing, can't wait to mount them, had way to much going on today to make any good
progress. But the wings are tiny and once I am happy with everything I will finish them easily.
I'm waiting to see if Mirce glued the round spar permanently into the wing, I don't see why it would need to be removed,
but I just want to be sure. I will add some set screws for the square spars so they can be removed, just some 1/4" ply on
the bottom and a hole drilled and tapped, but I will also leave them in the wing.
