RCU Forums - View Single Post - BJ Craft Etude
Thread: BJ Craft Etude
Old 03-01-2017 | 07:43 PM
  #120
mgosson
My Feedback: (8)
Default Firewall Update Part 2
The firewall is now completed.
Soldered 4 mm Castle bullet connectors to the Himax 6330-210 motor leads, added heat shrink tubing. Connected to a 70 mm Falcon three blade spinner.
I used Hysol 1C (that's what I had while waiting for the HP 60 to arrive). The adhesive sets up in 25 minutes, dries white and easy to work with. Applied an adequate amount on both sides of the firewall. To keep the lines of epoxy straight I placed masking tape to the fuse and the firewall to replace an ugly mess. Spread the epoxy, worked into the gaps and removed the tape.
I placed a 1 mm carbon fiber sheet sandwiched between the motor and firewall with a 2 mm plate on the rear of the firewall. This helps spread the load when you wrench down on the motor mounting bolts, IMO, and prevents the oversize washers from crushing the wood. Applied loctite thread locking paste (blue) to the motor bolts and called it a day.
This is as good as I get.
Next step, cut the cooling vents on the underside of the fuselage.
ID:	2203608   Click image for larger version
ID:	2203609   Click image for larger version
ID:	2203610   Click image for larger version
ID:	2203611   Click image for larger version
ID:	2203612   Click image for larger version
ID:	2203613   Click image for larger version
ID:	2203614   Click image for larger version
ID:	2203616   Click image for larger version
