RCU Forums - View Single Post - Vanessa c.g. Rig: How to.
Old 03-03-2017 | 06:34 PM
  #214
Tom Nied's Avatar
Tom Nied
"centered in each loop", good chance I'm not quite right. I'm using the one big loop of line that goes around the fuselage. This was the first hanging and I'm thinking by this time in the day my accuracy is not as good as it could be.
Loop direction, pretty sure I've got this right. Turning the dowel and on both sides either the nose goes up or down. No opposing forces. Although, I do have 7 wraps, maybe I should go down to 5 for easier re-positioning. I will recheck this.
Thanks ET for taking a look at it. I'll recheck my work this weekend. If preliminary indications are even close, my CG is not too bad, which is remarkable. The problem with the Giant Super Sporster is, is that it is so damn big (14.2 lbs) from what I'm use to, it turns into a wrestling match.
