Originally Posted by
Tom Nied
Wait a minute, you're telling me post 12 & 13 are wrong? That is exactly how my line loops around the dowel. When I turn the dowel, both lines on each side move in the same direction moving the nose either up or down.
It seems to me that with that setup you would get a twisting motion. IIRC correctly this was discussed in this thread. I will check that out on my rig tomorrow and let you know what I find. Will see if I find it in the thread. That setup pictured makes no sense to me. It may be part of the problem with the dowel alignment. Having it as I described I get an easy nose up or nose down motion.
