Almost ready now my Widgeon , built from RCM plans , the wing is 3 piece pink jackofoam cores sheeted with 1,5mm balsa ,tail wing built up sheeted with 1mm balsa ,fuselage sheeted with 2mm balsa on the sides and bottom is thin ply sheet covered with epoxy and glass. Rest is covered with monokote.
Engines OS 46LA ,it will be 4,5kg dry ready to fly.
